Where can I find this command?
Hi, all
I cannot find the location of this command.
Could anyone show me? Many thanks~image
it’s called path mapper.
Thanks! Have Found it
Path mapper is not easy to master and even if you do, it makes fragile models that break easily when data trees/paths change. I’ve managed to avoid it for many years and am happier without it.
@Joseph_Oster is right. If you post your definition maybe we can help you avoid using Path Mapper
Yes, you are right. When I use it , I just need more steps to cull pattern
most of what you might want to use path mapper to do, you can accomplish with some combination of trim tree, shift paths, and occasionally flip matrix. That doesn’t cover everything, of course, but in my experience so far, it covers almost everything.
Thanks Max. I might need more further study of the data family to work smoothly with them :thinking:
