I was working with a user on a Grasshopper solution and used the PathMapper to solve a part it, so I put together a tutorial and wanted to share here. Would love to hear if you have encountered situations where it was useful to use the PathMapper in Grasshopper.
Yes I tried to use the PathMapper component a few times, but even with some brief explanations from some users, I couldn’t understand how it works correctly. The +/- logic is clear to me, but I can’t apply the method correctly and this is something I promised myself to study in more depth. So I hope you will share other similar videos that explain how to do it even in complex situations.
If you encounter a situation where you think a PathMapper is useful, please share to see if we can help, but I agree the syntax is not very intuitive, and there are a few videos that explain it well (a few are linked to see below). I hope they help
I don’t have a visual example, but I do have a very specific usecase where the PathMapper seems necessary: the Weaverbird plugin has components that Subdivide meshes. If one branch in the tree is empty, it will NOT increment that specific path, while it does increment the paths of the branches that are filled. This is a big issue for scripts that use complex data tree structures. So I use PathMapper and fill in 2 or more input path formats, with the same output path format.
