V5
It would sure speed up my constant flitting in and out of wireframe/ shaded modes to have a keyboard shorcut for each.
I also need one desperately to access the ediot for dims, I double click at the moment but with surfaces and shaded mode I need to enter wireframe to do so.
need it for Dimension curve length
for Text blocks
for Linear Dimension and aligned dimension.
I hope one shortcut can do all three.
What are the macros I need to enter into the keyboard window in properties ?
Can I have a keybd shortcut to select last and then give it BringForward ?
i.e. how does one string two commands in that order of happening together ?
Steve, if you right click annotations in the selection filter, your double-click will only select the three cases you mention - then right click again to get the selction filter back to where it was.
The filter can be floating, docked or toggled to suit your needs.
Not sure I follow this., unless its buried deep in the links but a quick look through didnt find it for me, maybe I missed it…
but…
Where do I get the macro code line for enter wireframe
ditto enter shaded ?
again not understanding the right click, it turns off all the ticks but annotation, but I see nothing else.
My brain cant relate that to shaded/wireframe toggling.
I have also had need of a string of commands that do :-
project with delete, then BringForward, then Dimension on Curve then BringForward that dimension
Any kind soul care to write that one out so I can give it a keyboard shortcut ? please
Ideally it would be project with delete, then select nearest (to me) then BringForward, then Dimension on Curve then BringForward that dimension
also
