V5.
I have a cylinder sticking out of a solid planar block and need to slide it to the right a bit.
I could explode and move it then join side to top, then be left with a hole and have to create a new hole for it.
Is there a command to select the parts that make up the cylinder (sidewall and end cap) and slide it healing the hole and creating a new one where I end the move ?
I recall SpaceClaim can move Rhino objects around on their solids as such.
and also holes in solids, so if one has a rivet hole in the wrong place it can be moved.
Can Rhino now do that ?
…update MoveFace does it
just moved my smile upwards…couldnt resist that !
I also see MoveHole
Cheers
Steve
