V5
It warns of problems when I select what looks like a closed curve, for which I had to run ‘close curve’ to get a closed curve. It said a line had to be added to close a gap.
I then do a solid extrude and it warns of intersecting curve.
I explode and joing one length at a time and see no small segments,at completion visually it says its an open curve.
IntersectSelf command is shown as unknown command in V5.
I have projected the curve to a planar surface, result also still has warning.
Thanks,
so CrvEnd is now being added to my useful commands list, for spotting pesky areas where closeCrv causes a Zig Zag which unless found is a nuisance.
Caused by trimming curves of similar radii to tangent circles using the latter.
