Steve1
1
V5
section through a mesh
wish to redraw it neater, dont need the minute wiggles.
FitCrv just ends up with loads of control points.
I type in RedrawCrv no command it says.
wish there was a glossary or thesaurus at times.
redraw curve with minimum of control points.3dm (252.2 KB)
Steve
Gijs
(Gijs de Zwart)
2
You can try Rebuild. Since you have Rhino 8, you can also download Rhino 9 WIP, which has a new rebuild under the workname Elmo.
Questions you need to answer:
Max. point count
Max. deviation.
if you dont mind getting rid of the ugly polyline, i would use RebuildCrvNonUniform, less expirimenting cuts a bit quicker to the chase in my opinion.
Steve1
4
currently in V5 again, whilst awaiting advice on v5 million dollar question, and pixelation, and save times, and buttons to toolbars.
RebuildCrvNonUniform sounds good.
Steve
