I have many small and large curves and i need to reduce control points from them.
I tried all rebuild commands, but it work depends from lenght
How to rebuild (reduce control points) from curves but independently lenght.
Big sorry for my english.
One tool you might try is FitCrv. which is also known as Refit Curve to Tolerance. This tool tries to maintain the shape of the original curve with as few control points as possible, within whatever tolerance you specify. The tighter the tolerance, the higher the point count. The greater the tolerance or deviation you will allow, fewer points will be required.
This tool is nice because it lets you determine how accurately the curve will be, compared to the original. With the Rebuild tool, as soon as you reduce the point count, the shape begins to change, sometimes by quite a large amount, so that’s where FitCrv can be helpful.
Best regards,
Doug
