Hey, I was wondering if its possible to warp an object so that it can bend along a surface? If so, how can this be done?
I found the bend command. Problem already solved.
to be more exact i would use the Flow commands, either Flow which flows along a curve, or FlowAlongSrf which flows along a surface.
Yes that worked better thank you.
