I’m trying to use a curve as a voronoi source, but grasshopper won’t take the curve as-is, it interpolates certain control point positions to make a simple rectangle.
I’ve also tried to use a rectangle, and then use the curve to make a boundary surface, but it cuts off the voronoi cells. (left version uses base curve, right version attempts to use rectangle to build, and curve to crop)
you can have voronoi cells on any arbirary planar surface by first populating a geometry with points (so the points populate the custom surface) then by using the Brep | Brep component to intersect the voronoi with the original surface
