Hi guys, I have problems installing the lastet version 2:
It installs just fine but upon launching Rhino I get this error:
Any idea on what I can try?
Hi @Holo, try to uninstall VisualARQ and install it again.
If problem persists, then go to Rhino Options > Plug-ins and click on the install button, and select the “visualarq.rhp” file that you will find in this directory: C:\Program Files\Rhino 6\Plug-ins\Tibidabo
Also make sure the plug-in “Tibidabo” is loaded.
Then restart Rhino.
Let me know if the problem persists.
Cheers,
Hi Francesc, yeah, I got it working before I saw your response.
(I uninstalled and reinstalled a few times, then restarted, and then looked in the msi file and saw the pluginsfiles and searched for them and dragged them into Rhino and then it worked.)
Any idea why the plugin doesn’t find the plugin and managed to do this automatically?
The odd thing is that the error message is with out any detail.
Hi @Holo we have seen similar problems when installing a new version of VisualARQ after the plug-in was manually disabled from the Rhino Options. But I’m not sure if this is the reason of your case.
Anyway, I’m glad you made it work again.
Cheers!
Thanks for the feedback.
It was on my laptop, and I might have disabled it because I often use Move Vertical with the shortcuts M enter V enter and every now and then I hit V enter first by mistake and that launches VisualArq.
