As you can see, in v7 when navigating, after some stutter - the boxed preview turns on instantly, while v6 doesn’t have any problem navigating and rendering the viewport.
All the settings are set to Rhino’s default values, except that the Rendering material preview is set for the Arctic view, and in v66 the gamma is lower.
I would like to note that the v7 views even without the rendering materials, but with the single material, even tho much better, it’s still slower than in v6.
The default renderer is VRay5.
I have 2 quite good machines that shouldn’t be having any problems with this model.
One i7 gen4 16GB RAM GPU-GTX1070 8G
One i9 gen9 32GB RAM GPU-GTX2070 8G
Yes, it looks like something is definitely wrong in your v7 performance. Would it be possible for you to send us the model so that we can take a look? You can send it privately through this link: https://www.rhino3d.com/upload?to=david.eranen@mcneel.com.
Also, can you post your System Information that you get from Rhino 7 by going to Help -> System Information…?
Finally, can you check if the problem fixes itself if you don’t load VRay on startup?
The performance issue you are experiencing has been fixed in Rhino 7 SR 2. You are going to have to wait until it is released (hopefully soon). You can speed up the viewport meanwhile by disabling Edge Softening on the objects.
Great! Thank you.
As for edge softening - It doesn’t actually improve it as much.
Side-note - is there a way to see which edges cannot be softened in a model.
The command prompt tells us that there are some, but it would be nice if we could see which ones.
Last update has fuycked something up. Now Arctic displays control points, and there is no way of removing them. Have tried every single setting but they remain there. It is on Meshes . Surfaces display aright…
