Viewport Capture to Bitmap - how to set extents
Hi everyone,
I’m trying to capture the document from a certain viewport and am using the following VB code to do so:
    Dim View As Rhino.Display.RhinoView = document.Views.ActiveView
    If View.Equals(Nothing) Then
        Return Rhino.Commands.Result.Failure
    Else
        Dim capture As Bitmap = View.CaptureToBitmap()
        capture.Save(FilePath)
    End If
In the Rhino print dialog there are the options Viewport, Extents, Window.
How can I mirror the effect of ‘Extents’ - i.e. capture everything in the document, and use the ActiveView only to decide which direction to capture from? Should I be changing the variable “View” above, or are there arguments of CaptureToBitmap() to do this?
CaptureToBitmap() works like the ViewCaptureToClipboard and ViewCaptureToFile commands - it does not work like printing. If you want to capture some else, (e.g. the extents), then you will have to manipulate the view before capturing.
– Dale
You would need to do something like call
document.Views.ActiveView.MainViewport.ZoomExtents()
before capturing is you want to capture extents
Perfect, thanks!
