I am using a simple python script that captures to file all the named views of my rhino files.
Everything is fine until I try to run it trough the server machine in which we have a time based licence.
The server machine does not have a video card.
Is there any way around this?
Hi Andrea,
I solved it by scripting a render.
FWIW a dressed down verion of what we have running:
def render_preview(export3D_path):
rs.EnableRedraw(False)
rs.UnselectAllObjects()
#if not rs.IsViewMaximized(): rs.Command('!_MaxViewport ')
rs.ViewProjection(mode=2)
rs.Command('!-ViewportProperties CameraTarget w-10,-10,10 w0,0,0 _Enter')
rs.Command('!ZEA ')
preview_path = os.path.join(export3D_path, 'preview.png')
#RENDERING
sc.doc.Lights.Skylight.Enabled = True
#sc.doc.GroundPlane.AutoAltitude = True
sc.doc.GroundPlane.Enabled = False
rs.Command('!_-DocumentProperties Render Resolution Type=Custom Width=640 Height=360 _Enter _Enter _Enter')
rs.Command('!_Render ')
rs.Command('!_-SaveRenderWindowAs "{}" '.format(preview_path))
rs.Command('!_-CloseRenderWindow ')
sc.doc.Lights.Skylight.Enabled = False
HTH
-Willem
