Wiley
January 18, 2022, 11:47am
#1
List < Point3d > scaledPts = new List{pt1,pt2,pt3};
foreach(Point3d scaledpt in scaledPts)
scaledpt.Z += 2;
I would like to add 2 to the Z value of all the points in list. how do I do that?
Error
Error (CS1654): Cannot modify members of ‘scaledpt’ because it is a ‘foreach iteration variable’ (line 94)
variables in foreach are locked, use a for loop instead:
for(int i = 0; i < scaledPts.Count; i++)
scaledPts[i].Z += 2;
Wiley
January 18, 2022, 12:15pm
#3
Point3d pt1 = new Point3d(0.0, 2.0, 6.0);
Point3d pt2 = new Point3d(12.0, 6.0, 6.0);
Point3d pt3 = new Point3d(5.0, 14.0, 14.0);
List < Point3d > pts = new List<Point3d>{pt1, pt2, pt3};
for(int i = 0; i < pts.Count; i++)
pts[i].Z += 2;
A = pts;
I tried. Still not working
Apologies @Wiley
use the below
Point3d pt = pts[i];
pt.Z += 2;
pts[i] = pt;
A = pts;
menno
(Menno Deij - van Rijswijk)
January 18, 2022, 12:21pm
#5
Point3d
is a struct
, not a class
. So when you get the variable from the list, it gets automatically copied on the stack, you don’t get a reference. That is why you need to re-assign it to the list, so after modification it gets copied into the list again.
Wiley
January 18, 2022, 12:24pm
#6
@menno thanks
I see so I cannot set property directly with Structure.
Just for my curiosity and education.
Is there a neater way to do it with Where/Select using System.Linq?
Baris
January 18, 2022, 12:53pm
#7
you could also move them with a Vector:
private void RunScript(List<Point3d> pts, ref object A)
for (int i = 0; i < pts.Count; i++)
pts[i]+= new Vector3d(0, 0, 2);
A = pts;
menno
January 18, 2022, 2:27pm
#8
If you could use Point3dList
instead of List<Point3d>
you could do this:
Point3dList scaledPts = new Point3dList{pt1,pt2,pt3};
list.Transform(Transform.Translation(0,0,2));
Point3dList is defined in RhinoCommon, see below for documentation
Point3dList Class
