hi everyone
is there a way to creat vertical text in rhino?
when i creat text in rhino with “text object”, the text that created, it’s formed horizontal.
i want it to be vertical.
how can i do it?
thank’s
hi everyone
how can i do it?
thank’s
unfortunately not…
i found that this has been wished 3 years ago here but it has been ignored since.
here a tracker for the wish. i would see use for this myself.
doing it manually can of course work but this is bothersome if you have to break each letter separately, editing this would be just pure waist of time. and even worse text aligned along a curve like below would imply breaking the editability completely.
we can ask @lowell if he knows any kind of progress,
or if any intentions exist to make that happen at all.
ok
thanks
the only way to creat vertical text and not manually is to creat it in a grahpic program that can do this, save as a curves, and then import it into rhino and extrude.
or Maybe Other 3d software and import it into rhino.
I can’t help feeling that there must be a way to do this using Grasshopper.
I have been trying using ‘orient’ component but difficulties arise with letters/numbers which are comprised of more than one curve, like R ,P, A, etc.
So far I’ve not succeeded…
Done it!
Make the text curves into surfaces using ‘boundary surface’
Then Orient using planes on a vertical line divided by the number of letters
Finally extract the edges.
Job done
