Ventana de opciones
Hi there,
I’m starting to use Rhino for Mac, I have a problem with the options window in the PC version out this window at the end of the deployment of tools, know as I can find the options window in the Mac version.
Thank you.
ES:
Hola,
estoy empezando a usar Rhino para Mac, tengo un problema con la ventana de opciones, en la versión para PC esta ventana salen al final del despliegue de herramientas, Saben como la puedo encontrar la ventana de opciones en la versión para Mac.
Gracias.
Mac is a bit different with respect to this sort of thing. To follow their conventions you will use Settings and Preferences instead.
The Document Setting portion of Options are in Settings, and the Rhino Options portion can be found in Preferences.
