Hello everyone!
I’m trying to simulate a script from the RhinoPythonPrimer101.pdf that can be found here. On page 43 there is an example to iteratively shorten a curve, under the heading Nested Lists.
Here is my code and I’m getting this error:
Message: ‘Vector3d’ object has no attribute ‘float’
(Before that I was getting a “Expected float, got point3D” message, so I tried to change vm to float(vm) on line 15…)
What do you think is wrong?
''' python
def smoothingvector(point, prev_point, next_point, s):
pm = (prev_point+next_point)/2 #middle point between the previous and next point
va = rs.VectorCreate(pm, point)
vm = rs.VectorScale(va, s)
return vm
def smoothcurve(curve_id, s):
curve_points = rs.CurvePoints(curve_id, s)
new_curve_points.append(rs.AddPoint(curve_points[i], float(vm)))
for i in range(1, len(curve_points)-1):
vm = smoothingvector(curve_points[i], curve_points[i-1], curve_points[i+1], s)
knots = rs.CurveKnots(curve_id)
degree = rs.CurveDegree(curve_id)
weights = rs.CurveWeights(curve_id,0)
newcurve_id = rs.AddNurbsCurve(new_curve_points, knots, degree, weights)
if newcurve_id: rs.DeleteObject(curve_id)
return newcurve_id
def iterativeshortencurve():
curve_id = rs.GetObject("Open curve to smooth", 4, True)
if curve_id is None or rs.IsCurveClosed(curve_id): return
min = rs.Distance(rs.CurveStartPoint(curve_id), rs.CurveEndPoint(curve_id))
max = rs.CurveLength(curve_id)
goal = rs.GetReal("Goal length", 0.5*(min+max), min, max)
if goal is None: return
while rs.CurveLength(curve_id)>goal:
rs.EnableRedraw(False)
curve_id = smoothcurve(curve_id, 0.1)
rs.EnableRedraw(True)
if curve_id is None: break
if( __name__ == "__main__" ):
