Hello
I am a beginner of RhinoPython and learning through the book RhinoPythonPrimerRev3, Unfortunately. I encountered problems in the example exercises. the following is my code and return, please give me a hint, and where can I understand Different similar issues…
I have been troubled for a long time, because the information searched in the forum is incomplete.
thank you very much~
> import rhinoscriptsyntax as rs
> def smoothingvector(pt, prevpt, nextpt, s):
> pm = (prevpt+nextpt)/2.0
> va = rs.VectorCreate(pm, pt)
> vm = rs.VectorScale(va, s)
> return vm
> def smoothcurve(crv_id, s):
> crv_pts = rs.CurvePoints(crv_id)
> newcrv_pts = [ ]
> for i in range(len(crv_pts)-1):
> vm = smoothingvector(crv_pts[i],crv_pts[i-1],crv_pts[i+1],s)
> newcrv_pts.append(rs.PointAdd(crv_pts, vm))
> knots = rs.CurveKnots(crv_id)
> degree = rs.CurveDegree(crv_id)
> weights = rs.CurveWeights(crv_id,0)
> newcrv_id = rs.AddNurbsCurve(newcrv_pts, knots, degree, weights)
> if newcrv_id: rs.DeleteObject(crv_id)
> return newcrv_id
> def iterativeshortencurve():
> crv_id = rs.GetObject("open curve to smooth", 4, True)
> if crv_id is None or rs.IsCurveClosed(crv_id): return
> min = rs.Distance(rs.CurveStartPoint(crv_id), rs.CurveEndPoint(crv_id))
> max = rs.CurveLength(crv_id)
> goal = rs.GetReal("Goal length", 0.5*(min+max), min, max)
> if goal is None: return
> while rs.CurveLength(crv_id)> goal:
> rs.EnableRedraw(False)
> crv_id = smoothcurve(crv_id, 0.1)
> rs.EnableRedraw(True)
> if crv_id is None: break
return:
Message: Could not convert [<Rhino.Geometry.Point3d object at 0x0000000000000067 [-28,29,0]>, <Rhino.Geometry.Point3d object at 0x0000000000000068 [-4,34,0]>, <Rhino.Geometry.Point3d object at 0x0000000000000069 [2,-15,0]>, <Rhino.Geometry.Point3d object at 0x000000000000006A [22,-7,0]>] to a Point3d
