VBScript Runtime error - Type mismatch
Hello everyone,
I’m using Rhino 6 at work, and I use a script made by a former colleague to import XCAT phantoms (as Nurbs (.nrb) files) into Rhino. Somehow, the script worked on his workstation, but not on mine, and I can’t see why.
Here is the script :
Sub importPhantomCT
Dim arrPoints, arrCount(1), arrKnots(1), arrDegree(1), arrWeights(1), arrVector
Dim line, srfInfo
Dim iFilesys, iFiletxt
Dim strFilename, strSurface, layerName, material, comp
Dim num_surfs
strFilename = Rhino.OpenFileName("Open...", "NRB Files (*.nrb)|*.nrb||")
If IsNull(strFileName) Then Exit Sub
Rhino.print "Filename = " & strFilename
If Not IsNull(strFilename) Then
	Set iFilesys = CreateObject("Scripting.FileSystemObject")
	Set iFiletxt = iFilesys.OpenTextFile(strFilename, 1)
	num_surfs = 9999
	arrDegree(0) = 3
	arrDegree(1) = 3
	For n = 0 To num_surfs - 1
		layerName = iFiletxt.ReadLine  'blank space
		layerName = iFiletxt.ReadLine  'title
		material = iFiletxt.ReadLine  'material ID
		comp = iFiletxt.ReadLine  'material ID
		'      Rhino.Print "Material = " & CStr(material)
		line = iFiletxt.ReadLine
		srfInfo = Split(line, " ")
		arrCount(0) = CInt(srfInfo(0))
		arrCount(1) = CInt(srfInfo(0))
		line = iFiletxt.ReadLine  'Ignore 1st zero
		arrVector = arrKnots(1)
		ReDim arrVector(arrCount(1)+1)  'ignore 1st zero and last 1
		For v = 0 To UBound(arrVector)
			arrVector(v) = CDbl(iFiletxt.ReadLine)
		Next
		arrKnots(1) = arrVector
		line = iFiletxt.ReadLine  'Ignore last 1
		arrVector = arrKnots(0)
		ReDim arrVector(arrCount(0)+1)
		Next
		arrKnots(0) = arrVector
		ReDim arrPoints(arrCount(0)*arrCount(1)-1)
		For v = 0 To UBound(arrPoints)
			arrVector = arrPoints(v)
			ReDim arrVector(2)
			arrVector(0) = CDbl(srfInfo(0))
			arrVector(1) = CDbl(srfInfo(1))
			arrVector(2) = CDbl(srfInfo(2))
			'        arrVector = Rhino.Str2Pt(line)
			arrPoints(v) = arrVector
		Next
		strSurface = Rhino.AddNurbsSurface(arrCount, arrPoints, arrKnots(0), arrKnots(1), arrDegree)
		If Rhino.IsLayer(layerName) Then
			Rhino.ObjectLayer strSurface, layerName
		Else
			Rhino.AddLayer(layerName) '<<<<REMOVED
		End If
		Rhino.ObjectName strSurface, material & ";" & comp
	Next
End If
iFiletxt.Close
End Sub
Rhino.AddStartupScript Rhino.LastLoadedScriptFile
Rhino.AddAlias "importPhantomCT", "_noEcho _-Runscript importPhantomCT"
And the first lines of the .nrb file I try to import :
chest_surface
5
1.0
50 :M
53 :N
U Knot Vector
0.000000
0.000000
0.000000
0.000000
0.020000
0.040000
The thing is, when I launch the script and I select this file, I get nearly immediatly an error message telling me :
Microsoft VBScript Runtime Error
Type Mismatch : 'CDbl'
Line : 43
Car : 4
Code :
This refers to the line " arrVector(v) = CDbl(iFiletxt.ReadLine)", but I can’t see why is there a mismatch.
And obviously, yes, the script worked for this file and many others on my colleague’s workstation (which is unavailable for now on, as my colleague).
Thanks, Vince
Hi Vince - hard to say without the input file - if you put a break point at that line in the script, what value does arrVector(v) have? If there are many repetitions in the loop before it breaks and it’s too tedious, one thing I do is something like
		Rhino.Print v
	Next
Let it break and note the last print of v
then go back and put
            if v = (that number) then
               Rhino.Print "OK"   '<<<< break point here so you can see what  arrVector(v) is
            End if
	Next
And put your break point at the Rhino.print “OK” statement.
Hi Pascal, thanks for the advice !
I tried what you suggested, and the thing is that it breaks when v = 0 for the first thing, and when I run the breakpoint, arrVector(v) is empty when the the breakpoint is triggered (which is pretty logic), and it breaks when I execute the next line.
-Vince
Hi Vince - it it breaks on the first run then there is no need for all the fancy stuff I described (and yes, I was mixing in python, thanks for pointing that out, fixed above) .
So, I’d set a variable to iFiletxt.ReadLine and see what that actually is.
Well, it just reads the first line of decimals, so it is just 0.000000. I tried decomposing everything in that step, by declaring a “res” variable and doing this :
        res = iFiletxt.ReadLine
        Rhino.Print res
        res = CDbl(res)
        arrVector(v) = res
Next
But it doesn’t have any effects, the problem still lies with the CDbl function…
-Vince
Post the file causing the problem.
// Rolf
I can neither upload it as it is too large (83,8MB) nor retranscript it here as it contains over 2M lines, but I don’t think it comes from the file, as my colleague used to be able to work it out with this same file.
-Vince
Do your collegue and you have the same locale settings? Specifically decimal separator…
I just learned about this issue a few minutes ago, I’m looking into it.
-Vince
Well, that was that… On my computer, the decimal separator is the comma, when on my colleague it seems that it was the point… Thank you all for your help !
