I tried it on rhino 6. Sorry it doesn’t work
' ConvertBlockToGroup.rvb -- March 2010
' If this code works, it was written by Dale Fugier.
' If not, I don't know who wrote it.
' Works with Rhino 4.0.
Option Explicit
' Main procedure for script
Sub ConvertBlockToGroup()
' Local variables
Dim arrBlocks, strBlock, arrObjects(), nBound
' Get blocks to explode
arrBlocks = Rhino.GetObjects("Select blocks to convert", 4096, True, True)
If IsNull(arrBlocks) Then Exit Sub
' Explode the blocks
For Each strBlock In arrBlocks
' Reset our array of objects
ReDim arrObjects(-1)
' Explode the block
Call BlockExplode(strBlock, arrObjects)
' See if any objects were added to our array
On Error Resume Next
nBound = UBound(arrObjects)
If (Err.Number = 0) Then
' Group the objects
Call Rhino.AddObjectsToGroup(arrObjects, Rhino.AddGroup())
End If
Next
End Sub
' Explodes a block and all of its nested blocks
Sub BlockExplode(ByVal strBlock, ByRef arrObjects)
' Local variables
Dim arrExplodes, strExplode
' Explode the block
If Rhino.IsBlockInstance(strBlock) Then
arrExplodes = Rhino.ExplodeBlockInstance(strBlock)
If IsArray(arrExplodes) Then
For Each strExplode In arrExplodes
' Recusive call...
Call BlockExplode(strExplode, arrObjects)
Next
End If
Else
' Add the object to our array
Call ArrayAdd(arrObjects, strBlock)
End If
End Sub
' Adds a new element to the end of an array
Sub ArrayAdd(ByRef arr, ByVal val)
Dim ub
If IsArray(arr) Then
ub = UBound(arr)
If Err.Number <> 0 Then ub = -1
ReDim Preserve arr(ub + 1)
arr(UBound(arr)) = val
End If
End Sub
