Hi!
I found a useful script that converts blocks to groups. Is there also a solution that does the opposite?
Regards,
Thomas
Hi!
Regards,
Thomas
Dunno… maybe the following works for you? --Mitch
Edited - updated
import Rhino
def onegroup_filt(rhino_object, geometry, component_index):
return rhino_object.GroupCount==1
def GetSingleGroup(obj):
og=rs.ObjectGroups(obj)
if og and len(og)==1:
return og[0]
def ConvertGroupToBlock():
msg="Select group of objects to convert to block"
err_msg="Too many groups found!"
g_objs=rs.GetObjects(msg,group=True,preselect=True,custom_filter=onegroup_filt)
name=GetSingleGroup(g_objs[0])
if name:
for i,obj in enumerate(g_objs,1):
if GetSingleGroup(obj) != name:
print err_msg ; return
else:
origin=rs.coerce3dpoint([0,0,0])
msg="Block instance insertion point? (Enter for World Origin)"
insert_pt=rs.GetPoint(msg)
if not insert_pt: insert_pt=origin
block=rs.AddBlock(g_objs,origin,name,delete_input=True)
rs.InsertBlock(block,insert_pt)
Thanks, would it be possible to convert multiple groups at once?
I avoided that to maximize the chances of success… As you know any object can be a member of more than one group - possibly even nested groups. So asking the user to select a single group at a time and excluding any object that was in several groups is how I approached not possibly creating a mess…
I’ll have a look to see if there’s a reliable way to screen all possible selected groups to make sure they’re unique and not nested…
–Mitch
You can try this one… All bets are off if objects are in nested or overlapping groups… Use at your own risk.
def ConvertGroupsToBlocks():
if not objs: return
group_set=set()
for obj in objs:
obj_g_names=rs.ObjectGroups(obj)
for g_name in obj_g_names:
group_set.add(g_name)
all_obj_groups=list(group_set)
#all_obj_groups should now contain unique list of groups
for group in all_obj_groups:
g_objs=rs.ObjectsByGroup(group)
block=rs.AddBlock(g_objs,origin,group,delete_input=True)
rs.InsertBlock(block,origin)
Haha thanks!
I’m sure we don’t have nested or overlapping groups.
As always all production companies use autocad, so we need the grouped parts to be blocks…
Hi Helvetosaur
Can I convert multiple blocks into groups?
