i want to create a 3D Extrusion of a text element.
My script does NOT raise any errors, it just does not show me an extruded 3d Object in Rhino, the text stays a flat planar surface…
Thanks in advance.
Greets
Mr. Sinter
Code:
import Rhino as rhi
#CREATE TEXT AS PLANAR SRF
zero = (0,0,0)
text_guid = rs.AddText("NAME", zero, height=20.0, font="Arial")
text_in_curves = rs.ExplodeText(text_guid, delete=True)
text_as_srf = rs.AddPlanarSrf(text_in_curves)
#DELETE TEXT OUTLINE CURVES
fubar = 0
for element in text_in_curves:
rs.DeleteObject(text_in_curves[fubar])
fubar = fubar + 1
#CREATE EXTRUDE PATH
extrude_path = rs.AddLine((0,0,0), (0,0,10))
objectref_path = rhi.DocObjects.ObjRef(extrude_path)
path_curve = rhi.DocObjects.ObjRef.Curve(objectref_path)
#EXTRUDE SRF ALONG PATH
foo = 0
for element in text_as_srf:
object_reference = rhi.DocObjects.ObjRef(text_as_srf[foo])
brep_face = rhi.DocObjects.ObjRef.Face(object_reference)
print "%s"%brep_face
brep_extrude = rhi.Geometry.BrepFace.CreateExtrusion(brep_face, path_curve, True)
print "%s"%brep_extrude
foo = foo + 1
#DELETE EXTRUDE PATH
rs.DeleteObject(extrude_path)
Rhinoscriptsyntax methods generally work with objects already in the document and their result usually also generally adds the objects automatically to the document. RhinoCommon methods do not. So you have created your extrusion with
Geometry.BrepFace.CreateExtrusion()
but you have not added it to the document, so at the end of the script, it just “evaporates”.
Generally, communication with the active document is done via scriptcontext. I added a few lines to your script below to show you how it works:
import Rhino as rhi
import scriptcontext as sc
zero = (0,0,0)
fubar = 0
fubar = fubar + 1
foo = 0
#add your object to the document here
sc.doc.Objects.AddBrep(brep_extrude)
#Delete the surface object
rs.DeleteObject(element)
foo = foo + 1
#Redraw the screen
sc.doc.Views.Redraw()
