just installed Rhino 6 and tried recompiling and running a big and very important plugin I wrote in VB.NET with Rhinocommon (new reference to the rhinocommon.dll in Rhino 6 folder).
The behaviour is different, something goes wrong and I can’t apparently stop at breakpoints using Visual Studio…
Any ideas? Is there a VB.NET migrating guide as the one you provided for C/C++? (http://developer.rhino3d.com/guides/cpp/migrate-your-plugin-manual-windows/)
I need to set the plugin up and running on Rhino 6 as soon as I can :-/
Cheers
f
Hi @fabiopasquarell,
Most Rhino 5 plug-in that reference RhinoCommon just work in Rhino 6.
Have you tried to load your Rhino 5 plug-in in Rhino 6?
To build a true Rhino 6 version of your plug-in:
1.) Load your plug-in project in Visual Studio
2.) Modify the project settings to target .NET Framework 4.5
3.) Remove the reference to RhinoCommon and re-add it referencing the version of RhinoCommon that is included with Rhino 6
4.) Click the Build button.
– Dale
Hi Dale,
thank you for the hints.
The Rhino plugin in version 5 is loaded into Rhino 6, and the compatibilty check is OK.
Anyway, the plugin does not work properly as in version 5… bad controls layout on the base panel, no auto-spawing of other needed forms on load etc.
So I tried setting the .NET framework to 4.5 (I was working on 4.6), re-applied the rhinocommon.dll from the Rhino 6 folder, gave the debug start from Rhino6.exe.
But the situation was the same. I can’t stop at breakpoints, like it somehow “misses” them.
I attach the code for the command and the plugin class, if you have some time to give it a look… panel contains a form, form contains controls… I’d like to break on the form load event to see what’s happening inside…
I can actually break on:
Protected Overrides Function OnLoad(ByRef errorMessage As String) (see code)
I can see the panel popping up on Rhino 6 but from there on, no breakpoints on the solution are effective.
Hope I explained my problem well.
Thank you!
fVisualBender.zip (2.1 KB)
Does your breakpoint turn into a hollow circle
️ instead of a filled red circle when you attempt to debug your plug-in? If that happens, maybe Rhino is loading the wrong rhp (check your pluginmanager paths) or a pdb file is not getting created next to your rhp file when compiling.
Hi Steve,
yes, I double checked rhp path and I’m using the correct one.
Breakpoint is a filled red circle (see pic).
Further investigations made me realize that the form_Load event is not fired, while the form_Shown is fired.
So I’m trying to migrate the form_load code somewhere else in order to match my needs.
It’s a bit strange, but I think I’ll manage somehow.
If you have any ideas about the missed form_load event it would help.
Cheers
f
Hi Dale,
I’ve tried to load my Rhino 5 plug-in in Rhino 6 but is doesn´t work. I’ve not changed the Rhinocommon, I’m using SR14…
Is it essential to change to version 6 of RhinoCommon or can it be done differently?
Thanks
Eliseo
Hi Dale,
The reported error is:
Error
* Assertion at metadata.c:939, condition `index < meta->heap_strings.size’ not met
Thanks
It sounds like our compatibility checker may be failing with your plugin. @will, can you take a look at this?
Hey @Eliseo, would it be possible to get a copy of your plug-in for testing (via private message, if you’d prefer)?
Hi Will,
I’ll make a reduced version and I’ll send you the plug-in.
Thanks
I’ve managed to reproduce this (logged as WWW-725). I think it has something to do with larger files getting corrupted/truncated before being passed to the compat tool.
This turned out to be an issue with running the compat tool under Mono. The compat.mcneel.com server is a Linux VM running the latest version of Mono. I’ll keep an eye on things…
You can download the compat tool from the GitHub repository and run it yourself on a Windows machine. Here is an example:
Path\To\Compat.exe -q Plugin.rhp "C:\Program Files\Rhino 6\System\RhinoCommon.dll"
Assuming there aren’t any obvious error messages, search the output for any occurrences of “✗”. Please ask me if you have any questions.
just to have the full info in one post:
c++
there is a nice Documentation for c++ plug-ins
c#
Before:
0.) Backup or commit to git ![]()
additionally:
open the yourPlugIn.csproj File of your Plugin in a texteditor / Notepad++
it is readable .xml
search for “32” and identify 32 bit configurations.
delete those configurations
search for Rhino
… you will find some path to Rhino 5
replace with path to Rhino 6
this will cause visual studio debug against Rhino 6
<PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug64|AnyCPU'"> <StartProgram>C:\Program Files\Rhino 6\System\Rhino.exe</StartProgram> <StartArguments> </StartArguments> <StartAction>Program</StartAction> <Prefer32Bit>false</Prefer32Bit> </PropertyGroup>
sorry for adding some info to old thread.
best, tom
