Hello all,
I am struggling to find the right method of implementing a controlled chamfer feature on thickened (solid) quad-dominant meshes. One interesting solution “for variable mesh offset” that was suggested by @DanielPiker, however, it does not meet my needs since I want “slope” to emerge at least 2 vertex rings inside from naked borders and also I’d like to have control over the thickness of the outer mesh border.
I think I got very close to the desired result using Stripper plugin, developed by @joncorrod, however it is quite difficult to implement vertex rings levels (using mesh strips) and my resultant mesh topology is open and invalid.
The final solid mesh needs to be quad-dominant since I want to further smoothen it in using Catmull Clark SubD.
I would be very grateful for any advice/thoughts on this! Rh/Gh files are attached (random geometry is internalised in Gh file). Stripper plugin is required to open the attached gh file (see hyperlink to the food4rhino website above).
Mesh chamfer using stripper.3dm (3.2 MB)
stripper.gh (1.7 MB)
