V8 Wish. Fillet Surface small improvement
Hi All,
Currently we have remembering of last radius amount after successful fillet creation only.
You run the command, input the number for radius, pick pair of surfaces and realise it’s too small. Now you need to extend surfaces so they’re closer to each other. Then you start FilletSrf again, but radius is the old one, not you just input.
I think command should remember last input no matter how successful was the result from previous run.
@Screamer I could not reproduce that here in the latest. Can you run _SystemInfo and post back the results?
I think he is talking about when you cancel the command before completion.
In previous versions Rhino would remember the entered radius even when the command was cancelled before completion.
Thank you, @jim
Exactly what I was talking about.
Sorry if misexplained.
got it, thanks
RH-85383 FilletSrf: always remember radius
RH-85383 is fixed in Rhino 8 Service Release 16
