Hi @3dsynergy,
I’m able to reproduce Rhino hanging when enabling the Curves post-effect after having used the NVIDIA denoiser. I made a YouTrack item: https://mcneel.myjetbrains.com/youtrack/issue/RH-60949.
-David
Hi @3dsynergy,
-David
Hi @DavidEranen, @John_Brock
Thanks for your hard work on this. The denoiser is working incredibly well I’m thankful McNeel is so aggressive at ironing out these minor bugs. Means a lot to us users.
RM
Hybrid machine WILL 100% EVENTUALLY HAVE DISPLAY ISSUES unless they are set up correctly to use the Nvidia.
please look at this post.
https://discourse.mcneel.com/t/soooo-you-bought-a-laptop-with-hybrid-graphics-and-rhino-doesnt-run-right-read-this/109982/2
If you don’t force your machine to use the Nvidia when using Rhino by following the instructions above, it will constantly try to use the intel because that is how hybrid machines typically work.
Just because you haven’t had problems in the past does not mean you won’t have problems in the future. If you are using the Nvidia denoiser and your machine is trying to use the intel, I’m not surprised you are seeing issues.
Hi @theoutside,
Yep good article. I did that already and always have to watch windows power settings I have them turned to high performance due to latency issues on laptops when doing musical scoring so it’s not just Rhino that needs these settings.
Next Machine I won’t get hybrid seemed like a good idea at the time. I’m looking at something with the Nvidia 3080 but I don’t see any machines with them yet, I’ll have to look harder.
RM
