Using VR Headsets to Walk Through a Rhino model
Hi All,
I am wondering if anyone is successfully using VR Headsets (like the MetaQuest 3S, for example) to walk through a Rhino model of an architectural interior? I know there have been some posts on this in the forum, but I don’t see anything conclusive or recent.
Thank you.
Cosmas Demetriou
Set Designer
Hi @cosmas
We used Simlab’s super simple plugin to view Rhino models in VR a few years bsck. It’s a cheap, no frills solution, but was super stable and simple for our use. The fidelity is not UE5, but worked well for our use. I have no idea if it’s totally outdated by now :joy:
Another option is to use Twinmotion, which allows you to turn on VR in both presenter- and editor mode. I don’t have much experience with TM, but it seemed fairly easy to get started. I merely tested it - never used it for “real” work!
There’s been plenty of discussion on the topic before.
HTH, Jakob
Hey Cosmas,
we use Enscape and META Pro.
works.
Eike
Works with Rhino?
Sorry about that. I see that you’re using Enscape as a work around to Rhino. Makes sense. Wonder if anyone else has had experience with this?
@cosmas Yes, we use Rhino/Enscape and Rhino/Twinmotion with Meta Quest 2 & 3 for a more experiential understanding of student designs in my architecture studio classes.
I’ve used successfully Fologram when it had a free tier, it worked like a charm, but it was AR not VR
Try TwinMotion, it IS unreal 5. VR by the click of a buttons.
