Using rtree
I am trying to make use of rtree to get points within a boundingbox.
Until now I am able to create an rtree object.
But I have to admit I have no Idea how to call a search and get the results back.
import Rhino as rc
pcloud = rs.GetObject("Select pointcloud")
pcloud_obj = rs.coercegeometry(pcloud)
box = rs.GetObject("Select box")
box_obj = rs.coercegeometry(box)
bbox = box_obj.GetBoundingBox(True)
rtree = rc.Geometry.RTree.CreatePointCloudTree(pcloud_obj)
rtree.Search(bbox,?)
Philip
Here’s a sample using the RTree search structure
That looks good. Thank you.
Here is a simpler test of rg.RTree I did a while back.
p
import Rhino.Geometry as rg
import random as rnd
import time
simple demo of rhino common's rtree to return points within a search volume.
def SearchCallback(sender, e):
    #you need a Searchcallback function
    result.append(e.Id)
rt = rg.RTree()
# individual points can be added, but I don't think you can retrieve them from the
# tree - so they will need to be tracked by their insertion index (which needs to be
# a unique integer, but not necessarily sequential)
# bounding boxes can also be added as can meshes and pointclouds
adict = {}
for i in range(1000000):
    pt = rg.Point3d(rnd.random()*100, rnd.random()*100, rnd.random()*100)
    # insert the point in the tree
    rt.Insert(pt, i)
    # record the point to look up from search result indexes
    adict[i] = pt
#build a search sphere
cp = rg.Point3d(20,20,20)
sp = rg.Sphere(cp, 3)
#you can also search a bounding box
bb = rg.BoundingBox(rg.Point3d(20,20,20), rg.Point3d(21.5,21.5,21.5))
start = time.time()
result = []
# do the search
print rt.Search(sp, SearchCallback, result)
print "Indices of points within search volume: ", result
print "The actual points: "
for r in result:
    print adict[r]
end = time.time()
print "time taken:", end - start
The example Steve posted finds a single closest point by using the callback in RTree to repeatedly search. Below is an example of a pure python kdtree by Stefan Kogel from the web. It returns a single closest point (not bounding box contents), and can work in 2,3 or higher dimensions. The second function is a test which compares its performance to straight brute force.
p
"""A Python implementation of a kd-tree
This package provides a simple implementation of a kd-tree in Python.
https://en.wikipedia.org/wiki/K-d_tree
__author__ = 'Stefan Kogl <stefan@skoegl.net>'
__version__ = '0.1'
__website__ = 'https://github.com/stefankoegl/kdtree'
__license__ = 'GNU General Public License v3 or later'
import math
from collections import deque
class Node(object):
    """ A Node in a kd-tree
    A tree is represented by its root node, and every node represents
    its subtree"""
    def __init__(self, data=None, left=None, right=None):
        self.data = data
        self.left = left
        self.right = right
    @property
    def is_leaf(self):
        """ Returns True if a Node has no subnodes
        >>> Node().is_leaf
        True
        >>> Node( 1, left=Node(2) ).is_leaf
        False
        return (not self.data) or \
               (all(not bool(c) for c, p in self.children))
    def preorder(self):
        """ iterator for nodes: root, left, right """
        if not self:
            return
        yield self
        if self.left:
            for x in self.left.preorder():
                yield x
        if self.right:
            for x in self.right.preorder():
                yield x
    def inorder(self):
        """ iterator for nodes: left, root, right """
        if not self:
            return
        if self.left:
            for x in self.left.inorder():
                yield x
        yield self
        if self.right:
            for x in self.right.inorder():
                yield x
    def postorder(self):
        """ iterator for nodes: left, right, root """
        if not self:
            return
        if self.left:
            for x in self.left.postorder():
                yield x
        if self.right:
            for x in self.right.postorder():
                yield x
        yield self
    @property
    def children(self):
        Returns an iterator for the non-empty children of the Node
        The children are returned as (Node, pos) tuples where pos is 0 for the
        left subnode and 1 for the right.
        >>> len(list(create(dimensions=2).children))
        0
        >>> len(list(create([ (1, 2) ]).children))
        0
        >>> len(list(create([ (2, 2), (2, 1), (2, 3) ]).children))
        2
        if self.left and self.left.data is not None:
            yield self.left, 0
        if self.right and self.right.data is not None:
            yield self.right, 1
    def set_child(self, index, child):
        """ Sets one of the node's children
        index 0 refers to the left, 1 to the right child """
        if index == 0:
            self.left = child
        else:
            self.right = child
    def height(self):
        Returns height of the (sub)tree, without considering
        empty leaf-nodes
        >>> create(dimensions=2).height()
        0
        >>> create([ (1, 2) ]).height()
        1
        >>> create([ (1, 2), (2, 3) ]).height()
        2
        min_height = int(bool(self))
        return max([min_height] + [c.height()+1 for c, p in self.children])
    def get_child_pos(self, child):
        """ Returns the position if the given child
        If the given node is the left child, 0 is returned. If its the right
        child, 1 is returned. Otherwise None """
        for c, pos in self.children:
            if child == c:
                return pos
    def __repr__(self):
        return '<%(cls)s - %(data)s>' % \
            dict(cls=self.__class__.__name__, data=repr(self.data))
    def __nonzero__(self):
        return self.data is not None
    def __eq__(self, other):
        if isinstance(other, tuple):
            return self.data == other
        else:
            return self.data == other.data
def require_axis(f):
    """ Check if the object of the function has axis and sel_axis members """
    def _wrapper(self, *args, **kwargs):
        if None in (self.axis, self.sel_axis):
            raise ValueError('%(func_name) requires the node %(node)s '
                    'to have an axis and a sel_axis function' %
                    dict(func_name=f.func_name, node=repr(self)))
        return f(self, *args, **kwargs)
    return _wrapper
class KDNode(Node):
    """ A Node that contains kd-tree specific data and methods """
    def __init__(self, data=None, left=None, right=None, axis=None,
            sel_axis=None, dimensions=None):
        """ Creates a new node for a kd-tree
        If the node will be used within a tree, the axis and the sel_axis
        function should be supplied.
        sel_axis(axis) is used when creating subnodes of the current node. It
        receives the axis of the parent node and returns the axis of the child
        node. """
        super(KDNode, self).__init__(data, left, right)
        self.axis = axis
        self.sel_axis = sel_axis
        self.dimensions = dimensions
    @require_axis
    def add(self, point):
        Adds a point to the current node or recursively
        descends to one of its children.
        Users should call add() only to the topmost tree.
        check_dimensionality([point], dimensions=self.dimensions)
        # Adding has hit an empty leaf-node, add here
        if self.data is None:
            self.data = point
            return
        # split on self.axis, recurse either left or right
        if point[self.axis] < self.data[self.axis]:
            if self.left is None:
                self.left = self.create_subnode(point)
            else:
                self.left.add(point)
        else:
            if self.right is None:
                self.right = self.create_subnode(point)
            else:
                self.right.add(point)
    @require_axis
    def create_subnode(self, data):
        """ Creates a subnode for the current node """
        return self.__class__(data,
                axis=self.sel_axis(self.axis),
                sel_axis=self.sel_axis,
    @require_axis
    def find_replacement(self):
        """ Finds a replacement for the current node
        The replacement is returned as a
        (replacement-node, replacements-parent-node) tuple """
        if self.right:
            child, parent = self.right.extreme_child(min, self.axis)
        else:
            child, parent = self.left.extreme_child(max, self.axis)
        return (child, parent if parent is not None else self)
    @require_axis
    def remove(self, point):
        """ Removes the node with the given point from the tree
        Returns the new root node of the (sub)tree """
        # Recursion has reached an empty leaf node, nothing here to delete
        if not self:
            return
        # Recursion has reached the node to be deleted
        if self.data == point:
            if self.is_leaf:
                self.data = None
                return self
            else:
                # find a replacement for the node (will be the new subtree-root)
                root, max_p = self.find_replacement()
                pos = max_p.get_child_pos(root)
                # self and root swap positions
                tmp_l, tmp_r = self.left, self.right
                self.left, self.right = root.left, root.right
                root.left, root.right = tmp_l if tmp_l is not root else self, tmp_r if tmp_r is not root else self
                self.axis, root.axis = root.axis, self.axis
                # Special-case if we have chosen a direct child as the replacement
                if max_p is not self:
                    max_p.set_child(pos, self)
                    new_depth = max_p.height()
                    max_p.remove(self.data)
                else:
                    root.remove(self.data)
                return root
        # Remove direct subnode
        if self.left and self.left.data == point:
            if self.left.is_leaf:
                self.left = None
            else:
                self.left = self.left.remove(point)
        elif self.right and self.right.data == point:
            if self.right.is_leaf:
                self.right = None
            else:
                self.right = self.right.remove(point)
        # Recurse to subtrees
        if point[self.axis] <= self.data[self.axis]:
            if self.left:
        if point[self.axis] >= self.data[self.axis]:
            if self.right:
        return self
    @property
    def is_balanced(self):
        """ Returns True if the (sub)tree is balanced
        The tree is balanced if the heights of both subtrees differ at most by
        1 """
        left_height = self.left.height() if self.left else 0
        right_height = self.right.height() if self.right else 0
        if abs(left_height - right_height) > 1:
            return False
        return all(c.is_balanced for c, _ in self.children)
    def rebalance(self):
        Returns the (possibly new) root of the rebalanced tree
        return create([x.data for x in self.inorder()])
    def axis_dist(self, point, axis):
        Squared distance at the given axis between
        the current Node and the given point
        return math.pow(self.data[axis] - point[axis], 2)
    def dist(self, point):
        Squared distance between the current Node
        and the given point
        r = range(len(self.data))
        return sum([self.axis_dist(point, i) for i in r])
    @require_axis
    def search_nn(self, point, best=None):
        Search the nearest node of the given point
        point must be a location, not a node. The nearest node to the point is
        returned. If a location of an actual node is used, the Node with this
        location will be retuend (not its neighbor) """
        if best is None:
            best = self
        # consider the current node
        if self.dist(point) < best.dist(point):
            best = self
        # sort the children, nearer one first
        children = iter(sorted(self.children, key=lambda (c, p): c.axis_dist(point, self.axis)))
        c1, _ = next(children, (None, None))
        if c1:
            best = c1.search_nn(point, best)
        c2, _ = next(children, (None, None))
        if c2 and self.axis_dist(point, self.axis) < best.dist(point):
            best = c2.search_nn(point, best)
        return best
    @require_axis
    def search_nn_dist(self, point, distance, best=[]):
        Search the n nearest nodes of the given point which are within given
        distance
        point must be a location, not a node. A list containing the n nearest
        nodes to the point within the distance will be returned.
        if self.dist(point) < distance:
            best.append(self)
        # sort the children, nearer one first (is this really necessairy?)
        children = sorted(self.children, key=lambda (c, p): c.dist(point))
        for child, p in children:
            # check if child node needs to be recursed
            if self.axis_dist(point, self.axis) < distance:
                child.search_nn_dist(point, distance, best)
        return best
    @require_axis
    def is_valid(self):
        """ Checks recursively if the tree is valid
        It is valid if each node splits correctly """
        if not self:
            return True
        if self.left and self.data[self.axis] < self.left.data[self.axis]:
            return False
        if self.right and self.data[self.axis] > self.right.data[self.axis]:
            return False
        return all(c.is_valid() for c, _ in self.children) or self.is_leaf
    def extreme_child(self, sel_func, axis):
        """ Returns a child of the subtree and its parent
        The child is selected by sel_func which is either min or max
        (or a different function with similar semantics). """
        max_key = lambda (child, parent): child.data[axis]
        # we don't know our parent, so we include None
        me = [(self, None)] if self else []
        child_max = [c.extreme_child(sel_func, axis) for c, _ in self.children]
        # insert self for unknown parents
        child_max = [(c, p if p is not None else self) for c, p in child_max]
        candidates =  me + child_max
        if not candidates:
            return None, None
        return sel_func(candidates, key=max_key)
def create(point_list=[], dimensions=None, axis=0, sel_axis=None):
    """ Creates a kd-tree from a list of points
    All points in the list must be of the same dimensionality.
    If no point_list is given, an empty tree is created. The number of
    dimensions has to be given instead.
    If both a point_list and dimensions are given, the numbers must agree.
    Axis is the axis on which the root-node should split.
    sel_axis(axis) is used when creating subnodes of a node. It receives the
    axis of the parent node and returns the axis of the child node. """
    if not point_list and not dimensions:
        raise ValueError('either point_list or dimensions must be provided')
    elif point_list:
        dimensions = check_dimensionality(point_list, dimensions)
    # by default cycle through the axis
    sel_axis = sel_axis or (lambda prev_axis: (prev_axis+1) % dimensions)
    if not point_list:
        return KDNode(sel_axis=sel_axis, axis=axis, dimensions=dimensions)
    # Sort point list and choose median as pivot element
    point_list.sort(key=lambda point: point[axis])
    median = len(point_list) // 2
    loc   = point_list[median]
    left  = create(point_list[:median], dimensions, sel_axis(axis))
    right = create(point_list[median + 1:], dimensions, sel_axis(axis))
    return KDNode(loc, left, right, axis=axis, sel_axis=sel_axis)
def check_dimensionality(point_list, dimensions=None):
    dimensions = dimensions or len(point_list[0])
    for p in point_list:
        if len(p) != dimensions:
            raise ValueError('All Points in the point_list must have the same dimensionality')
    return dimensions
def level_order(tree, include_all=False):
    """ Returns an iterator over the tree in level-order
    If include_all is set to True, empty parts of the tree are filled
    with dummy entries and the iterator becomes infinite. """
    q = deque()
    q.append(tree)
    while q:
        node = q.popleft()
        yield node
        if include_all or node.left:
            q.append(node.left or node.__class__())
        if include_all or node.right:
            q.append(node.right or node.__class__())
def visualize(tree, max_level=100, node_width=10, left_padding=5):
    """ Prints the tree to stdout """
    height = min(max_level, tree.height()-1)
    max_width = pow(2, height)
    per_level = 1
    in_level  = 0
    level     = 0
    for node in level_order(tree, include_all=True):
        if in_level == 0:
            print
            print
            print ' '*left_padding,
        width = int(max_width*node_width/per_level)
        node_str = (str(node.data) if node else '').center(width)
        print node_str,
        in_level += 1
        if in_level == per_level:
            in_level   = 0
            per_level *= 2
            level     += 1
        if level > height:
            break
    print
    print
test for kdtree
test for kdtree https://github.com/stefankoegl/kdtree
import time, math
import kdtree as kdtree
def rnd_pnt_lst(n):
    lst = []
    for i in range(n):
        lst.append(rnd_pnt())
    return lst
def dist(p1, p2):
    x, y, z = p1
    xx, yy, zz = p2
    return (xx - x)**2 + (yy - y)**2 + (zz - z)**2
def rnd_pnt():
    return (rnd.random()*100, rnd.random()*100, rnd.random()*100)
pt_lst = rnd_pnt_lst(100000)
pt = rnd_pnt()
tst_pt_lst = rnd_pnt_lst(10)
#build kdtree
start = time.time()
tree = kdtree.create(pt_lst)
#kdtree.add(pt)  # add new point to the tree
end = time.time()
print "time to build tree: ", end - start
#kdtree search
start = time.time()
for tpt in tst_pt_lst:
    closest = tree.search_nn(tpt)
end = time.time()
print "test point", pt
print "kdtree nearest neighbour: ", closest, "time: ", end - start
#kd_pt = closest[0].data
print closest
#print "kdtree distance: ", len(closest), math.sqrt(dist(kd_pt, tpt))
#for i in closest:
#    print i.data
#start = time.time()
#bal = tree.is_balanced
#end = time.time()
#print "balance: ", bal, end - start
def naive_nn(tpt, tst_pt_lst):
    #brute force
    start = time.time()
    d = 1000
    pp = (0, 0, 0)
        d = 1000
        for i in pt_lst:
            dd = dist(tpt, i)
            if dd < d:
                d = dd
                pp = i
    end = time.time()
    print "brute force: ", pp, "brute force time", end - start
#    print "brute force distance ", math.sqrt(d)
Thanks a lot Greenbox. Exactly what I was looking for.
