Hi guys,
I am doing some tests, were I am trimming a large point collection with a given closed mesh. Basically retrieving only those points which are inside.
Foremost, I want to try to use RTree
to only get the points which are inside the mesh’s bounding box, to then test that reduced search space for containment.
The RTree method I am trying to use is this one
The pseudo code which I have in mind is:
Construct RTree from points
foreach point in points:
if point is inside bounding box:
add point to newList
return newList
After I have this new List, it would be the input to:
/// <summary>
/// Tests weather a points is inside a closed mesh
/// </summary>
/// <param name="mesh"></param>
/// <param name="ptsRTree"></param>
/// <returns></returns>
public void ContainmentB(Mesh mesh, List<Point3d> ptsRTree)
for (int i = 0; i < ptsRTree.Count; i++)
Point3d pointOnMesh;
Vector3d normalAtPoint;
int a = mesh.ClosestPoint(ptsRTree[i], out pointOnMesh, out normalAtPoint, 0);
if(a > -1)
double dotProduct = normalAtPoint * (pointOnMesh - ptsRTree[i]);
// if pt is inside
if(dotProduct > 0)
culled.Add(ptsRTree[i]);
Would the pseudo code for the RTree search seem reasonable?
currently I have this:
public void ContainmentRTree(Mesh mesh)
RTree rTree = RTree.CreateFromPointArray(pts);
foreach (Point3d p in pts)
List<Point3d> inBox = new List<Point3d>();
EventHandler<RTreeEventArgs> rTreeCallback =
(object sender, RTreeEventArgs args) =>
inBox.Add(pts[args.Id]);
if(rTree.Search(bBox, rTreeCallback))
ContainmentB(mesh, inBox);
But I know its totally wrong for the following reasons:
Should be out of the loop.
Should also be out of the loop. It does not make sense to call this method here, because it will run in every iteration of the loop.
- For that matter the call back would have to bee defined in a different way. But right know I cant think of a way to do so.
Other details:
Currently without RTree and for 64 million points the code is taking roughly 3 minutes to complete. This is why I want to try to use RTree to cut down the performance a little.
I am not outputting the points in the viewport. I am overriding
ClippingBox
andDrawViewportWires
Any tips would be great!
