I am trying to use the network components from Heteroptera in Hops. When doing so I get the folowing errors:
Object reference not set to an instance of an object.: component “” (0114415b-8aac-4a98-9808-c9875e7fc09b)
Solution exception:Object reference not set to an instance of an object.: component “Network From Lines” (2449bb99-5ae1-433d-a32f-41d2874fab65)
I have contacted Amin Bahrami from Hetroptera. Het checked the script and he managed to run the script on his computer without any problems. Why is it not running on my computer.
Are you using the latest version on heteroptera? Perhaps it may be because of the mismatching the index of parameters in different version of Heteroptera. unlikely to be but still a unpredicted case,
It work smoothly on my computer with Hops
so its essential to ensure that you use a same version of plug-in everywhere. However I doubt that I changed this component recently which cause the problem .
Bests,
Amiin
I just tested on an other computer in the office but it was still not running and throwing out the same type of error. I also installed the latest version of Heteroptera.
On my computer I have Rhino version 7SR11(7.11.21293.9001,2021-10-20) and Heteroptera 0.7.2.4.
I do not know with which version Amin managed to make it work.
In the mean time I ran the script without hiding the console. This produced the folowing error message:
ERR] An exception occurred while processing request
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary2.get_Item(TKey key) at Heteroptera.GraphNet.P2C(Dictionary2 p)
at Heteroptera.GraphNet.P2C(IEnumerable1 p) at Heteroptera.GraphNet.set_Topology(List1 value)
at Heteroptera.GraphNet…ctor(GH_Structure`1 pt)
at Heteroptera.NetworkRegion.SolveInstance(IGH_DataAccess DA)
at Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)
[09:13:22 ERR] Solution exception:The given key was not present in the dictionary.: component “Region (Perceptive)” (baed3358-fe87-4bab-baa0-c92ea82700de)
::1 - [2021-11-02T09:13:22.0949076+01:00] “POST /grasshopper HTTP/1.1” 500 -
info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
Executed endpoint ‘/grasshopper HTTP: POST’
info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
Request finished HTTP/1.1 POST http://localhost:6500/grasshopper application/json;+charset=utf-8 1148 - 500 - - 30.3560ms
info: rhino.compute.ReverseProxyModule[0]
Max concurrent requests = 4
