Could anyone please help me with the following problem; using Galapagos in Grasshopper.
I would like to change the genomes; variable x and variable y so that the result of the given function, 0.0000045*x³+y, reaches the defined number in the panel. The number in the panel can be defined as 46.71 , for example.
My idea is to use division component A/B between the result of the function R and the defined number in the panel. Here the result of the function R is defined as A and the number in the Panel is defined as B.
So Galapagos should change the variable x and variable y to get A/b=1. However, I do not know how to set up the options in Galapagos in order to solve this problem.
Here is a screenshot of the problem.
Here is the Grasshopper code.
Galapagos_Dec_11.gh (11.0 KB)
