Hello everyone, i believe i have a very basic question to answer.
I have two closed planar curves inside of each other, i have divided them with the same number of points.
Then arranged the points to obtain lines which will slice the area between the curves (see the picture).
What i wanna achieve in the first step is to calculate the area of each slice, then i will try to expand the uses of the formula.
I want to achieve this with VB.net script to make it also a learning process for VB.Net with grasshopper. But i am having trouble selecting curve segments and lines in a list. To calculate the area of each slice i need to get 2 curve segments and 2 lines. When i try to use the curve and line lists in the VB script as arrays, i am getting errors. (maybe related the way i define the input objects?)
Any help about the solution and any sources/videos suggestions to understand the grasshopper/rhino scripting better would be appreciated.
