Dear Friends,
I’m trying to create a floor plan in the given curve/region. So that i offset the boundary curve and created an inner curve and divide the both curves created a line through the point’s between two curves. The issues I’m facing is i need the line to be in 90 degrees and i need to know the individual box/division area. Help me out thanks in advance.
Attachment available:
Curve rhino 6 file.
Grasshopper definition image.
I think you’re looking for “Perp Frame” and “Curve closest point”. I made a boundary surface from the offset curves then used the line from the points to split the surface into your “rooms.” Then just ran the area.
Thank you so much both @s.doscher@anon39580149 i combined both of your idea’s and created this solution. And once again thanks Seghier for your second solution Split gh.
