I have some problems with using user dictionary, I was searching for possible causes all over the forum, but without success.
I think, that problem might be related with this one:
And the problem is, that I can’t write surface with user dictionary, this is the code:
public Result Build1stOrderQuadAsSurfaces(List gcoords, MyGelmnt1 element, MyGelref1 gelref1, RhinoDoc doc)
var defaultAttr = new ObjectAttributes();
defaultAttr.ObjectColor = Color.Green;
defaultAttr.ColorSource = ObjectColorSource.ColorFromObject;
Point3dList point3dList = new Point3dList();
point3dList.Insert(0, P3d(gcoords, element.Nodin[0]));
point3dList.Insert(1, P3d(gcoords, element.Nodin[1]));
point3dList.Insert(2, P3d(gcoords, element.Nodin[3]));
point3dList.Insert(3, P3d(gcoords, element.Nodin[2]));
int count = (int)Math.Sqrt(point3dList.Count);
var srf = NurbsSurface.CreateFromPoints(point3dList, count, count, 1, 1);
srf.UserDictionary.Set("Elno", gelref1.Elno.ToString());
srf.UserDictionary.Set("Matno", gelref1.Matno.ToString());
srf.UserDictionary.Set("Addno", gelref1.Addno.ToString());
srf.UserDictionary.Set("Intno", gelref1.Intno.ToString());
srf.UserDictionary.Set("Mintno", gelref1.Mintno.ToString());
srf.UserDictionary.Set("Strano", gelref1.Strano.ToString());
srf.UserDictionary.Set("Streno", gelref1.Streno.ToString());
srf.UserDictionary.Set("Strepono", 0);
srf.UserDictionary.Set("GeonoOpt", gelref1.GeonoOpt.ToString());
srf.UserDictionary.Set("FixnoOpt", gelref1.FixnoOpt.ToString());
srf.UserDictionary.Set("EccnoOpt", gelref1.EccnoOpt.ToString());
srf.UserDictionary.Set("TransnoOpt", gelref1.TransnoOpt.ToString());
if (doc.Objects.AddSurface(srf, defaultAttr) != Guid.Empty)
return Result.Success;
return Result.Failure;
This part, doesn’t show any properties applied to surface:
protected override Rhino.Commands.Result RunCommand(RhinoDoc doc, Rhino.Commands.RunMode mode)
Rhino.DocObjects.ObjRef objref;
var rc = Rhino.Input.RhinoGet.GetOneObject("Select Face", false, Rhino.DocObjects.ObjectType.Surface, out objref);
if (rc != Rhino.Commands.Result.Success)
return rc;
GeometryBase srf = objref.Surface();
if (srf.UserDictionary.ContainsKey("Elno"))
RhinoApp.WriteLine("{0} = {1}", "Element number ", srf.UserDictionary["Elno"].ToString());
return Rhino.Commands.Result.Success;
can you please help?
