I’m have some problerm about set UserDictory data on Extrusion Object.
I want to Set an key to all of the Object when the object once add into the Rhino Document.
But I find that . Only the Extrusion could not to be set UserDictory. My C# is As Fellow:
(The Code is to set UserDictory to the object when object add to the RhinoDocument)
Sorry, Thankyou for your attention @dale
The code is attached below;
1、Get KeysComponent.cs file is an Grasshopper component to get all the key of an geometry
2、GrasshopperPluginInfo.cs file is used to add an keys when the geometry was created and add into Rhino WorkPlace. GetKeysComponent.cs (2.4 KB) GrasshopperPluginInfo.cs (3.0 KB)
