wynott
(Ryan Wynott)
1
How do I update a “sub-linked” block. I.e. a block within another block?
Block manager shows it as linked file is newer, however the update button is deactivated because it’s inside another block.
When I update the parent, the children don’t get updated.
Only way to achieve this seems to be to close Rhino and re-open.
There must be a better way. What am I missing?
pascal
(Pascal Golay)
2
It does look like this is not happening… a simpler update for now would be
! Save Revert
@mary - should that work, in the current scheme of things? (The OP’s scenario)
mary
(Mary Ann Fugier)
3
Hi Ryan and Pascal,
You are not missing anything.
This is how Rhino works, or does not work, right now.
I will get this posted as a bug.
Let’s see if the developers can “smooth” this behavior out.
I like Pascal’s work around.
Thanks for pointing this out.
Sincerely,
Max Fugier
