EricM
(Eric Paul Marvets)
July 13, 2026, 7:00pm
1
I’m updating a child obj’s parent.
const CRhinoHistoryRecord* record = object->HistoryRecord();
if (nullptr == record)
return 0;
ON_HistoryRecord* copy = doc->m_history_record_table.GetPrunedHistoryRecord(record->RecordIndex());
if (nullptr == copy)
return 0;
ON_SimpleArray<ON_UuidPair> remap(1);
ON_UuidPair& pair = remap.AppendNew();
pair.m_uuid[0] = oldParentId;
pair.m_uuid[1] = newParentId;
copy->RemapObjectIds(remap);
CRhinoHistory history(copy);
CRhinoHistoryManager* manager = RhinoHistoryManager();
const bool bRecording = manager->HistoryRecordingEnabled();
manager->EnableHistoryRecording(true);
const bool rc = doc->m_history_record_table.CreateObjectHistory(
const_cast<CRhinoObject*>(object), history);
manager->EnableHistoryRecording(bRecording);
Afterward, how do I get history to replay with the new parent, as you would with _HistoryUpdate?
dale
(Dale Fugier)
July 13, 2026, 8:12pm
2
Hi @EricM ,
You cannot update history as a command operation. That is, this is something you cannot trigger mid-command.
That said, you might be able to trigger an update in an idle event handler. In this case, this might work:
void HistoryUpdateDescendants(unsigned int docSerialNumber)
CRhinoDoc* pDoc = CRhinoDoc::FromRuntimeSerialNumber(docSerialNumber);
if (nullptr != pDoc && 0 == pDoc->InCommand(true))
CRhinoHistoryManager* pHistoryManager = RhinoHistoryManager(pDoc);
if (pHistoryManager)
pHistoryManager->UpdateDescendants(*pDoc);
– Dale
EricM
(Eric Paul Marvets)
July 13, 2026, 9:06pm
3
Hmm…that’s not ideal. I was able to get it to update by treating it like a normal command. After the remap, I replaced the parent in doc objects with no changes, which triggered a history replay on the child. However, that also broke history on the parent.
What if after I remap the parent, I copy the parent’s history record, replace the parent obj in the doc, and then push that history record back into the table?
EricM
(Eric Paul Marvets)
July 13, 2026, 10:33pm
4
Oh, what about UpdateDescendants()? If you can’t update within a command, where is this meant to be run from?
dale
(Dale Fugier)
July 13, 2026, 10:51pm
5
Hi @EricM ,
From rhinoSdkObjectHistory.h:
// Expert user tools
// - no support available
// - can change without notice
CRhinoCommand::result UpdateDescendants(class CRhinoDoc& doc);
I’ve already mentioned how you might use this.
Rhino’s command manager calls this after executing your command.
– Dale
