Rhino v4
I have Show Grid Axes unchecked in Grid Options. Grid Axes not visible normally. When using Shade, they reappear.
Any way to make them invisible while using Shade?
Thanks
Rhino v4
Thanks
Hi C West,
the _Shade command is capable to override various display settings. If you set _DrawAxes=_No from the commandline while the command is active, the grid axes should become invisble. Does that help ?
c.
Do you mean the Shade command or Shaded display mode?
