Hi
Why the ruled surface which is untrimmed surface baked as polysurface ?
baking_.gh (12.0 KB)
Hi @anon39580149,
It’s a control point mismatch and the ruled surface wants the control points to align per count I believe.
Bottom control points (count/position as expected):
Top control points (extra near curve seam):
Recreating/rebuilding your top circle should fix it up just fine.
Hope that helps, cheers!
Thanks , that because i used adjust seam:
But still weird because Grasshopper recognize the shape as surface.
And this fix the output surface to bake it as surface:
Rhino.Geometry.Surface.CreatePeriodicSurface
hi you need custum bake by SplitKinkyFaces
=false
private void RunScript(Brep brep, bool bake, bool SplitKinkyFaces)
if (!bake) return;
var id = RhinoDocument.Objects.AddBrep(brep);
bool sp = false;
if (SplitKinkyFaces)
sp = true;
RhinoDocument.Objects.Replace(id, brep, sp);
Thank you for this script
