maje90
(Riccardo Majewski)
July 27, 2023, 12:29pm
1
Replicable in 8.0.23206.14395, 2023-07-25 :
perspective , shaded
create a SubD object (a thorus)
CTRL+SHIFT window select the whole SubD (so completely, also every sub-object)
trying to unselect (by clicking away, or unselecting only a part, or with ESC key) causes crash
In this case Rhino crashed already after CTRL + SHIFT window selection.
RhinoCrashDump.3dm (63.7 KB)
maje90
(Riccardo Majewski)
August 1, 2023, 5:20pm
3
I just saw a Rhino crash report submitted a few days ago where Rhino crashed in the 3dxrhino plug-in. Was this before you moved files around?
This ^ applies only if 3dconnextion USB dongle is plugged.
maje90
(Riccardo Majewski)
August 1, 2023, 5:40pm
4
@stevebaer
I reinstalled Rhino WIP.
3d mouse directions are ok now.
This bug still persist, I’ve just sent another Crash report.
Copying the description here again:
Replicable steps:
3dconnexion USB dongle (wireless) connected, 3d mouse is actually turned OFF
Start Rhino WIP
Select perspective view (no need to maximise)
Set Shaded display mode
Create a thorus SubD
Completely select the SubD with CTRL-SHIFT and window select
now crash might happens just after selecting or when you deselect.
Thank you for the support.
maje90
(Riccardo Majewski)
September 5, 2023, 10:52am
5
@Gijs similar case here, probably/maybe fixing this one solves also other similar cases:
opening WIP today
perspective viewport maximized (double click)
setting viewport to shaded (right click on blue tab)
creating a thorus subD
CTRL+SHIFT cross windows selecting it completely
deselecting (sometime not even needed) > rhino crash
Sent a report file crash with same description.
I can replicate this anytime. 5 out of 5 time now…
Gijs
(Gijs de Zwart)
September 5, 2023, 11:00am
6
@maje90 as mentioned, I don’t have a 3d connection mouse here to test that, but mentioned this issue internally.
wim
(Wim Dekeyser)
September 5, 2023, 11:23am
7
Hi Riccardo -
Just to make sure, have you modified the default Shaded display mode?
(From another report of yours, it sounds like you have).
maje90
(Riccardo Majewski)
September 5, 2023, 11:26am
8
I’m almost doing a _Reset every time i’m putting my hands on WIP.
It’s “vanilla”.
I managed to make it crash even with 3dmouse unconnected, but it happens rarely.
With 3dmouse connected it happens 100%.
stevebaer
(Steve Baer)
October 12, 2023, 5:40am
9
Just coming back around to make sure. We believe this crash has been fixed in the beta for a few weeks now. Please let us know if you are continuing to see a crash while using your 3d mouse.
maje90
(Riccardo Majewski)
October 12, 2023, 8:10am
10
Yes, I can confirm too. It doesn’t happen anymore.
Thank you!
