@scottd Reaching out to you Scott to see if you can move my learning about facades through a personal portfolio project toward completion. I have gotten to the point similar to Raffles City by UNStudio - Planar facade paneling post
and the post about
I was able to get planar panels, but like the doubly curved surface post, some of my panels are
- deviation too high
- Is there a way you can explain to replace similar types with a unit that fits in the model (if possible) meaning water-tight solid and imported into Revit with Rhino Inside Revit as curtain wall or does it need to be an adaptive component?
I do not know how to write the part of the script that decreases the deviation. How do people rebuild the curves? I can attempt to sketch out a method and work on rebuilding the curve if that would work.
240930 - Facade Script Post.gh (2.0 MB)
decrease the deviation and get panels within tolerance to be glass panels near the floor level until I hear from you. Please see the attached model and script file.
Thank you for the potential answer, and I will continue looking for the answer.
