I’ve searched the whole inter-webs and seems I cannot find a solution to this problem.
The problem is simple. example;
This is “Divide Distance”, not “Divide Length” so “mass addition” does not make sense here.
How do I get in the curve a point after point following the list order?
You want divide a curve with list of distances?
I would suggest using the mass addition, then use evaluate length with normalized to False
Sorry, I doesn’t work.
Because its the distance from point to point, not the length from point to point of the curve.
You got it, it’s exactly that!
I guess the key is a Python script?
Because I does not seem possible with standard GH.
Yes it is not possible with the actual component , and this work only with 2D curve.
divide_multi_distances.gh (10.8 KB)
HS_Kim
July 14, 2021, 3:35pm
7
You could also use a loop with anemone for instance…
DivideDist_re.gh (14.1 KB)
Thanks a lot!
This is a very useful tool.
Also, I just got Fennec
Cheers mate,
Nice! I tried this, make a loop using the circle cross method, but somehow I couldn’t get it to work, but you nailed it!
Thanks, it’s also a viable solution (which can be modified to work in 3D)
Cheers!
