Unable uninstall rhino.inside
“the specified account already exists.”
I’m not able to uninstall 1.35.9540.6370.
Revit is already uninstalled. Where can we find older versions maybe i can try repairing it since on website only newer version comes up
Hi HK2005,
That error is coming from the Windows Installer, not Rhino.Inside — it means the uninstall registration is broken, usually from an interrupted update.
i can send you the exact version you have installed (1.35.9540.6370) — run that msi and choose Repair, then the uninstall should work normally. Sending you a link privately.
If it still fails after the repair, lets try the Microsoft install/uninstall troubleshooter — run it, pick Uninstall, then select Rhino.Inside Revit from the list:
Thanks
Hi Japhy, I am also unable to uninstall the exact same Rhino.Inside version: Rhino.Inside® for Autodesk Revit 1.35.9540.6370. I have already tried repairing the Microsoft install/unistall troubleshooter, but it failed. It is looking for the exact msi which is now gone. Can you share the MSI?
Sent
