Unable to get ZooPlugin to load in Zoo 7
I am trying to create a Zoo Plugin for Zoo 7 for use with one of my products. I am able to compile this sample with the ZooPlugin.dll that comes with (I recognize this Git sample indicates Zoo 6 but I cannot find a Zoo 7 version)
Furthermore, I followed these instructions here on how to compile and install a Zoo Plugin (which appear to be for Rhino 5)
In any event, when I open Zoo 7, the product is not available. I did come across some vague references in some wiki articles for signing the plugin. I am currently signing using my company certificate - do I need a separate certificate from McNeel to get it to work with the Zoo?
Thanks,
-Nate
Hi @archinate1,
There is more up-to-date documentation on supporting the LAN Zoo here:
Rhino - RhinoCommon Guides
You can also find Zoo plug-in samples here:
https://github.com/mcneel/rhino-developer-samples/tree/7/zoo
And a Rhino plug-in sample that use the Zoo here:
https://github.com/mcneel/rhino-developer-samples/tree/7/rhinocommon/cs/SampleCsWithLicense
Yes, you must digitally sign both your Zoo and Rhino plugins, that use the Zoo, using a certificate signed by McNeel .
Rhino - Digitally Signing LAN Zoo Plugins
Hope this helps.
– Dale
Thanks @dale - this is a useful collection of links!
In my searching for Zoo reference material, the Rhinocommon resources were not where I was being directed to. I’m glad I asked!
