Unable to edit face color of polysurface object?
In Rhino 7 (7.3.21026.13002, 2021-01-26), I’m unable to define a Face Color for a closed extrusion (i.e. Box).
What I do is select the target face with SHIFT + CMD and in the Properties panel under Face Color, click on the small button that makes the color selection window pop up. Now, if I select a color and hit Apply nothing happens, and the small button remains in a pressed state.
Is this a bug or is it simply not possible to edit the colors of individual faces of a polysurface?
Edit:
Video footage
faces from extrusions seemed to be excluded from this function, it works only on polysurfaces.
Oh, I see. It would probably be better to grey the Face Color option out for these types of objects.
or simply allow to color faces of extrusion.
Wild guess (I don’t have V7): faces are inside out, you’re looking at the back side? Use flip to invert.
Nope. :wink:
I agree. Logged here:
RH-62789 Face Color appears enabled on subsurfaces of closed extrusions
Thanks for reporting this.
I was just checking on the status of:
and it does look like this issue is obsolete in Rhino 8 for Mac. Now you can sub-object select a face and override the Display Color from the Object Properties.
OK, thanks for the heads up. I haven’t upgrade yet.
