Unable to calculate Volume
My current project contains two sizes of threaded inserts known as Rampa insert. I modeled the outer thread so I can subtract it from 3D printed parts. The inside metric thread is simplified with a throughhole. The type I’m using has a hex drive.
Initially I modeled the hole and hexagon with the same diameter. The polysurface was closed so to me everything seemed fine. At the very end of my process I tried to calculate the weight of all my hardware and the volume calculation failed. I came to the conclusion that the hexagonal hole edges being coincident with the round hole are the start of the problem. Running _ShrinkTrimmedSrf results in a faulty polysurface.
The file below contains two cylinders. The volume can be calculated on the green object but not on the red one…
unable-to-calculate-volume.3dm (254.0 KB)
This is all I can share publicly.
I recently reported a problem where a block import failed. The file which repeatedly didn’t want to load in the first attempt contained a block with such a faulty threaded insert, actually 4 instances… Maybe related.
As mentioned in the linked topic, I was unable to reproduce the import problem with a simplified file. This is my definition:
System Info
Rhino 9 SR0 2025-5-20 (Rhino WIP, 9.0.25140.12305, Git hash:master @ d890ecce73c6f3a95029dec83812cb2b7774c990)
License type: Commercial, build 2025-05-20
License details: Cloud Zoo
Expires on: 2025-07-04
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.5
Computer platform: DESKTOP
Standard graphics configuration on OpenGL
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 5-12-2025 (M-D-Y). OpenGL(4.6.0 NVIDIA 573.24)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 5-12-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-12-2025
Driver Version: 32.0.15.7324
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25140.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
My guess is the BooleanDifference resulted one or more very narrow remnants of the circular hole surface remaining where the hexagon and circle were coincident. I recall something like that occuring a while back.
Added: Opened the attachment and cannot find any extra surfaces.
It’s 16 surfaces on both objects.
Interestingly the volume is calculated when before running ShrinkTrimmedSrf
The problem is the transitions between the round and hexagon holes. I found the problem by exploding, and then using Area. Area did not work on those parts.
I think so too
Actually just one of them does not work.
Fixed by deleting those surfaces and replacing with new transition surface. PlanarSrf the outer hex edges. Trim the middle using the cylinder.
BUT problem reoccurs if I shrink the transition surface.
May be worthwhile reporting as a bug.
I solved the problem by reducing the hole diameter for the round hole but in the end I think it is a bug too…
Hi Martin -
Thanks. I’ve put that sample on the list as RH-87599 ShrinkTrimmedSrf: Causes Volume To Fail
