You suggestion works like a charm. I moved all the curve to the world origin (0, 0, 0), and now the “region union” component works for all curves, as shown in the video below.
Thank you very much for the advice. I’ll pay attention to this “far from origin” issue from now on.
I’ve tested two new cases where the curves are close to the world origin point. However, only one works.
As shown in the example file, the workflow should create an outline for each cluster of overlapping curves.
As shown in the videos, the “region union” component works for the first case, but not the second one, and I’m sure what’s the difference between them that leads to the different outcome.
I’ve attached the updated GH file.
Hope you can kindly advise what is causing this issue.
