ULD load for beam karambaCommon
Hello
I am trying to create a uniformly distributed block load for a beam element in c# with the KarambaCommon API
so far I could not find the documentation on how to construct this
I was able to make point loads and mesh loads but I couldn’t find any class to construct a ULD for a beam.
I found the “DistributedForceLoads” but not sure if this is the right constructor for what I want to do.
the test file below was helpful but I don’t understand the arguments are or what this constructor does as the docs are not available.
Any leads would be greatly helpful
thanks in advance!
Hello Moo,
I think that the easiest way to create a uniformly distributed block load for a beam element is with Karamba.Factories.Toolkit.
Down here an example of a simple beam model set up:
namespace Example
    using System.Collections.Generic;
    using System.Linq;
    using Karamba.Elements;
    using Karamba.Geometry;
    using Karamba.Loads;
    using Karamba.Utilities;
    using KarambaCommon;
    using NSubstitute.Exceptions;
    using NUnit.Framework;
    public class UldSetup
        [Test]
        public void UldBaseSetup()
            // Setup the model entities.
            var builder = new Toolkit();
            var defaultCrossSection = builder.CroSec.CircularHollow();
            var loads = new List<Load>
                builder.Load.ConstantForceLoad(Vector3.UnitZ, 10),
            var beamBuilder = builder.Part.LineToBeam(
                new Line3(new[] { Point3.Zero, new Point3(1, 0, 0) }),
                "simpleBeam",
                defaultCrossSection,
                info: new MessageLogger(),
                out _);
            var supports = new[]
                builder.Support.Support(0, new[] { true, true, true, false, false, false }),
                builder.Support.Support(1, new[] { true, true, true, true, false, false }),
            // Assemble the model.
            var model = builder.Model.AssembleModel(
                beamBuilder,
                supports,
                loads,
                info: out _,
                mass: out _,
                cog: out _,
                msg: out _,
                runtimeWarning: out _);
            // Run the analysis.
            model = builder.Algorithms.AnalyzeThI(model, out _, out _, out _, out _);
            // Retrieve results for the beam at the mid point.
            var beam = (ModelElementStraightLine)model.elems.First();
            var position = 0.5;
            var state = beam.GetElementState(model, model.lc_super_model_results, position);
            var nx = state.GetForce(BeamDofs.t_x);
            var vy = state.GetForce(BeamDofs.t_y);
            var vz = state.GetForce(BeamDofs.t_z);
            var mx = state.GetForce(BeamDofs.r_x);
            var my = state.GetForce(BeamDofs.r_y);
            var mz = state.GetForce(BeamDofs.r_z);
            var tx = state.GetGlobalDisplacement(BeamDofs.t_x);
            var ty = state.GetGlobalDisplacement(BeamDofs.t_y);
            var tz = state.GetGlobalDisplacement(BeamDofs.t_z);
            var rx = state.GetGlobalDisplacement(BeamDofs.r_x);
            var ry = state.GetGlobalDisplacement(BeamDofs.r_y);
            var rz = state.GetGlobalDisplacement(BeamDofs.r_z);
KD
Enrico
Thanks Enrico, I will give this a shot
so if i understood correctly you are suggesting to use ConstantForceLoad from the Tookit?
Yes, because the toolkit is already set up to retrieve ready to use entities for a K3D model
