Actually, the workaround existed before TweenCurves - behind the scenes, the command simply does in one go the procedure we used to do to get intermediate curves before it existed…
Really could do with that option ThroughPoint as with one click job done, selecting curves cloning trimming sweeping the extracting isos took me a little longer .
Will this go onto a wish list or how do we get it onto such ?
There is no guarantee that a “tween” curve passes through the selected point. One possibility would be for the command to generate the “tween” curve which is closest to the selected point. Mitch’s workaround could be modified to do this:
Loft between the two curves.
Pull the selected point to the lofted surface.
ExtractIsoCurve at the point on the lofted surface.
Sorry I dont see that. Between two curves there would be an infinite number of tweenCurves and as such one has to pass through a point that sits somewhere between the two curves. (In ortho view)
