Hi! I was trying to use one script I made in the “editpythonscript” inside grasshopper with no luck. Not sure why it is not working, the scripts looks like this:
Since you’re writing about Grasshopper and Python, I’m guessing that you’re using the GHPython component?
If that’s the case, then you’ve forgotten to pass anything out of it. It has a default output a for this, which you can rename to whatever.
It works by passing something to a variable of the same name.
However, in your case your makeBox() function first needs to return something. Currently, it’s only calling rs.AddBox(), which adds a box to the Rhino document.
In Grasshopper, you’re better off using only RhinoCommon - the API -, and getting rid of the rhinoscriptsyntax code. It’s primarily meant to script in Rhino.
import Rhino.Geometry as rg
import math
HALF_PI = 0.5 * math.pi
def make_box(w, h, d, angle):
corners = []
delta = math.atan((w * 0.5) / (d * 0.5)) + math.radians(angle)
length = math.sqrt((d * 0.5)**2 + (w * 0.5)**2)
for j in xrange(2):
for i in xrange(4):
x = -math.cos(delta + i * HALF_PI) * length
y = -math.sin(delta + i * HALF_PI) * length
corners.append(rg.Point3d(x, y, h * j))
return rg.Box(rg.Plane.WorldXY, corners)
if __name__ == "__main__":
a = make_box(10, 20, 10, 5.0)
I don’t know what all the angle stuff is about, but this should work.
